メインコンテンツにスキップ
First generation of Citroen's supermini car.
20回答 すべてを表示
My rear door wont shut
The catch on the rear door of my 52 reg C3 is not working. The door simply wont shut no matter what i do?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
コメントを追加
1 件の回答
選択されたソリューション
Had that happen to me once. Somehow the latch gets in the closed position with the door open and blocks closing. Here's what I did--with the door open make sure its unlocked and operate the door handle. Hold it open and using a screwdriver flip the door latch to the open position. It should operate normally then. Good luck. Ralph
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Thanks ralph, i tried your suggestion and unfortunatley no joy. i have taken it to a garage to be told the lock mechonisim has gone. £170!!
さんによる
I know this post is very old but just in case you see it - Ralph, you are a lifesaver! I just had this problem on the hard shoulder of the M25 (my toddler had opened the door while we were driving, I pulled over to shut it and fix child lock and someone this happened). Tried to fix it but couldn’t work it out, saw your solution and it worked like a charm - I am SO grateful!
さんによる
コメントを追加
回答を追加する
leigh stevens さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 19
過去 30 日: 76
今までの合計 10,504
