Can I safely test the digitizer before I reassemble everything again?
hey everyone, I've got two dead digitizers now, the first one i noticed had a small tear in the flex cable (not sure how that happened..) so that was an obvious problem but this second one is in perfect shape. there is no damage to the connections and I have replaced all pieces of tape properly at the bottom of the digitizer. the digitizer is unresponsive.
can i safely test the digitizer before i reassemble everything again?
i know with iphone 5/c/s the flexes need to be folded properly or you have issues. is there a way to improperly fold the ipad mini flexes to render the touch bad? I feel i copied the original correctly.
thanks in advance.
この質問は役に立ちましたか?
