My trackpad is not working
My trackpad works fine to move the cursor around, but doesn't work when I try to click on anything. When I plug in an external mouse, it works fine. Is the trackpad broken, or is it possible some setting got changed.
It definitly could be a setting, unless no one else uses this mac but you and you didnt change the settings...?
When you press on the trackpad is there a clicking sound? if not the button under the trackpad may have collapsed (If the MacBook has seen a LOT of use) then the topcase will need replaced...
このアンサーは役に立ちましたか?
there is a clicking sound, but ive heard the track pad not working is a sign of a sagging battery, which is a sign you need a purchase a new one or get apple to fix it
-Sarah'
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 4,490
Does it move?
mayer さんによる
