What is the fastest and easiest way to take out loca glue
are there different methods of cleaning it after removing the screen
Try "Contact cleaner" spray, its not expensive but effective.
You can also use olive oil, works slowly but it works.
このアンサーは役に立ちましたか?
I use a spray gel version of goo gone. it works quite well if you let it sit for 20 min and remove with a plastic razor blade it will not harm the lcd.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 7
過去 30 日: 9
今までの合計 151
