having problems with facebook since insalling system update
I did the system update last nite. Today it will not let me go intob d ome facebook areas such as events or friends timelines. It tajes me back to menu everytime
Its probably the app error, its either not compatible with your device or the update aint working and needs fixing, id suggest to go to Google play, and leave a comment about your problem hoping it'll be taken into account, in a mean time id suggest to maybe uninstall the update?
このアンサーは役に立ちましたか?
How do you uninstall the update?
you go to Google play store, find the app you looking for and just tap on the uninstall button, that is if you have an internal Facebook app in your phone i mean if it came with your phone. Theres also an alternative option, you can download one of the "fake" Facebook apps, they are a lot smaller in terms of how much space they occupy on your phone, they aren't the real thing but at least they are user-friendly and you can still use Facebook :)
I also downloaded the update, now I cant get e-mails or internet. It hangs for a few seconds and then goes back to main screen. Its not an App problem, its the Samsung Update. Can't find a way to uninstall.
このアンサーは役に立ちましたか?
Same problems here, tried all of the suggested fixes as well and still no solution.
このアンサーは役に立ちましたか?
Im having the same problems with facebook.
このアンサーは役に立ちましたか?
Yep! A ton of people are having the same issue. On another website, someone posted they contacted Samsung and was told that the problem was with their TAB and to send it in...wouldn't it be a something if all sent theirs in-
I sent mine in and facebook app only opens for a few seconds and shuts down... worse than it was before!
Same probem as users have here with face book, but I also noiticed that youtube stops during viewing and SD card shows me that it was removed suddenly rror every time when Face book drops me out.
and ofcourese it started after I have updated to last version of 4.4.2
Waiting for solution from your side.
Michael
このアンサーは役に立ちましたか?
Finally I found people with the same problem I'm having. Still haven't seen zan answer. Does Google even care?
このアンサーは役に立ちましたか?
Just spoke to Samsung.....Facebook's app is the culprit - it is not compatible with the tablet's newest update. Contact Facebook to see when they will provide an update for their app. In the mean time go through your internet browser on your tablet to access facebook.
このアンサーは役に立ちましたか?
System updated my tab3 yesterday, as tab message requested I do so......... now facebook is not working properly. Whenever I try to go into notifcations facebook just hangs with a white screen for a couple of seconds then takes me straight out of facebook and back to my home screen! Have tried all the same things, as other people on here, to rectify the problem but nothing works?.......have also tried accessing via internet but still unable to easily access my notifications...........hate this new system update, wish I hadn't bothered as everything was running just fine before I did it.........feeling so frustrated and cross, facebook has now been rendered absolutely useless!!!!!!!.........if anyone knows how this problem can be rectified I would be very interested to know your solution........... : (
このアンサーは役に立ちましたか?
Mine now has the same problem. If you select facebook, it opens, then hangs, then goes back to the tablet homepage. Hope there's a solution soon. I have tried all the uninstall/reinstall, go back to a previous version, restarting everything, and nothing works. Commented on the facebook proram page, but heard nothing. Driving me crazy. Heeeeelllllllllppppppppp :-)
このアンサーは役に立ちましたか?
Try googling for an older version of facebook. Version 3.5 works. Once installed, go to google play and make sure auto update isnt selected
このアンサーは役に立ちましたか?
Same problems facebook shuts doen after 5 second with latest samsung update
このアンサーは役に立ちましたか?
Installed the latest update for Facebook a couple days ago and since then I cannot open up the account. When I click on the icon, it goes black and stalls my phone. I have to power off and restart my phone.
このアンサーは役に立ちましたか?
I cannot get my Facebook account on my Samsung Galaxy 6 phone send me code through text message as can't get emails as changed thank you
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 10
過去 30 日: 16
今までの合計 2,951
I am having the same problem.
Jane Spreier さんによる
I'm having the same problem.
Lou Snelling さんによる
Every time I try to do anything other then scrol, facebook returns me to the main tablet menu. I have re-downloaded facebook, turned the tablet off and restarted, and totally dumped all data (reset) and started again. Northing seems to work.
millieh さんによる
Me too! I have uninstalled and reinstalled the fb app with no success.
Richard Wardell さんによる
Now it says"systemui has stopped working"
