メインコンテンツにスキップ
Improved second generation Google-branded tablet with a 7" screen.
98回答 すべてを表示
締切られた回答
Power Adaptor acquired tempermental charging
Power pin on Nexus 7 32gb 2013 is tempermental when charging - loses connectivity to power cord. Jostling around the power cord can sometimes reconnect powering success.
What is the most likely solution and how to deploy? Professional help, since I'm not a technical geek?
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Esther, once the micro USB connector becomes loose, it most likely needs to be replaced. Since this is a relative new device, do check for any kind of warranty first. If you do not have any, I suggest that you get the power flex replaced. Of course, since your Nexus is already setup for wireless charging, and you are willing to live with a loose charging port, you could try a Wireless amazon, Ebay and many other places. Only bad thing is that wireless charging is not as fast as as it would be with your normal charger. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 148
