メインコンテンツにスキップ
モデル番号A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5もしくは 3.4 GHz Core i7 Processor, ID iMac12,2
708回答 すべてを表示
add SSD hard drive
Hello,This the question,,Some one have an Idea how to Take Out of this computer the sata cable and power cable to instal a SSD Hard drive out side of the computer..SOME iDEA THANK YOU.
That way we can change or upgrade the SSD at any time.
Thank you
Juan Grisales. this my email if some answer Thank you...
fotojuan2@yahoo.com
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
imac 27 2011
さんによる
コメントを追加
1 件の回答
ベストアンサー
Depends on your exact model. Your device ID is very generic.
All but the entry-level iMac "Core i5" 2.5 21.5" model could be custom configured with an SSD at the time of purchase in addition to a hard drive. With some effort, an SSD can be installed after purchase in these models as well.
For the secondary SSD in the "Mid-2011" 27-Inch models, OWC provides this helpful step-by-step video of the challenging disassembly and upgrade process by watching the video, you should have a good idea about whether or not you feel comfortable performing the upgrade yourself or if you would prefer to hire a professional.
If you choose to DIY purchase all the recommended tools from the appropriate guide. Study the guide and notes (not just look at them) before you begin. You will want to label and separate all the screws, and know in advance if a connector is a ribbon cable with a lock or a press connector so you do not tear connectors off the logic board.
If this answer is acceptable please remember to return and mark it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
juan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 222
