メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
915回答 すべてを表示
New Screen wont work, any ideas?
So I have a bit of a problem, I purchased a new screen for my cracked ipod touch, when I replaced it, the new screen wouldn't work, so to see if the new screen was faulty I checked it with another ipod touch and it worked fine. I put the old cracked screen back in the original ipod and that had no problem working. So now I cant figure out what the problem is, the new screen obviously isn't faulty because it works on the second ipod, and the original ipod works as it's own original cracked screen still works on it. Any ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
When you installing the new LCD screen, the iPod must be powered off. Disconnect the battery or stay the iPod switched on to drain the battery alone.
Regards.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
eanna Keane さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 52
