メインコンテンツにスキップ
モデル番号A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5もしくは2.8 GHz Core i7プロセッサ
432回答 すべてを表示
Fixing Keys on Wireless Keyboard
The caps lock key from my keyboard popped out accidentally and on trying to put it back I may have broken the small plastic which comes in between the key and the base.
Is it possible to fix it otherwise or can I buy a separate key from apple store.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
E-bay is your best source for key parts (scissors, nipples & keys).
I have cut and rubber cemented or siliconed nipples (functions like springs or riser) under keys.
The Teflon scissors can also be replaced (it's finicky and there is a "right side up" or "wrong side up" configuration to them). What can not be replaced is the aluminum hinges (little raised tabs with holes for the moving scissors) If they break off you're pretty much done.
The metal arms (on certain large keys and space bar) need to be correctly placed for those keys to work smoothly.
If this answer is acceptable please remember to return and mark it.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you so much. I broke those teflon scissors I guess. I'm not so good around technology, everything seems to break in my usage.
Your answer was really very easy to understand. Once again, THANK YOU.
さんによる
コメントを追加
回答を追加する
joe bob さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 122
