メインコンテンツにスキップ
The Samsung Wave II S8530 (or "Samsung Wave II") is the Successor of Samsung Wave S8500 smartphone running the bada 1.2 operating system designed by Samsung, which was commercially released on October, 2010.
Charging problem due to problem in charging pin of Mobile
I want to change the charging pin as it has damaged ,
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Sunil, it sounds like you are looking for part number 3722-002919, which is the micro USB port for your phone. You can get it from places like this as well as many others. It is soldered to the logic board, so it will require some great skills and good tools. you will have to disassemble your phone and remove the logic board to get to the port. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Hey sunil,
You can buy all of the accessories you need for this certain phone here
-Hope this helped
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
sunil さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 902
