メインコンテンツにスキップ
The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
How do I get the cameras to work again?
I have had this phone for 2 months and both cameras stopped working. I try opening the app and it instantly dies and goes back to the home screen. Also on snapchat the screen shows up black and will not show anything that the lens would be showing.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 117
50 件のコメント
If there's someone who can help me, my HTC can not take pictures.
さんによる
I have exactly the same problem on my camera and other apps such as instagram,snapchat,whatsapp every app that uses the camera does not let me take a picture, Someone please help it's stressing me out now I've had this problem for almost a month
さんによる
I have a solution that worked for me! Go into Settings - Power - Scroll down to the bottom and uncheck Fast boot - Restart Phone.
さんによる
My sefile is not run. And than dou effect is not work. Now i cant
さんによる
unchecking fast boot worked for me! yay thanks!
さんによる
45件以上のコメントを表示
コメントを追加
20件の回答
ベストアンサー
Hi Buddy
My HTC Camera is not working at all, when i tried to open the camera it open and it shows black screen and then after sometime it comes to home scree.
Can you tell me how to rectify this issue.
Rgds
Sameer
このアンサーは役に立ちましたか?
スコア 58
27 件のコメント:
Help me
さんによる
Privacy guard... Yeah.. Problem fixed. Thanks :)
さんによる
I didn't find Privacy guard. Where did you find it? The main camera is not working.
さんによる
Its worked!! Thank guys.
さんによる
Bro, I had also this problem. Now it solved
http://www.gogorapid.com/fix-samsung-gal...
さんによる
22件以上のコメントを表示
コメントを追加
try doing a hard restart . please update the phone software ,
please close all other background app and rsetart the system .
for more follow Guide - steps fix to Phone Camera in phone and try to see if this helps to fix the camera
このアンサーは役に立ちましたか?
スコア 12
1件のコメント:
My duo camera stopped working but front camera is still working well please help me .
さんによる
コメントを追加
Hey Jacob, here are some things things that I recommend you try:
-Try to 'clear data' under 'camera' in app manager.
-If you're using Lastpass try and do a factory rest.
- If you are using the Lastpass option "Enable fill into apps" and turn it on in accessibility settings then the camera issue might be there. Maybe if you turn it off camera works fine.
-Let me know what happens.
-Hope this helped
このアンサーは役に立ちましたか?
スコア 6
1件のコメント:
Please I need help my HTC m8 windows can't open camera
さんによる
コメントを追加
SUCCESS!!! first of all thank you for all the suggested solutions. What worked for me? Someone suggested that we should find the apps that use the camera and disable them and VIOLA!!!! that worked for me.
go to settings
then apps
click on each app and scroll to the bottom of each app (each one has to be done individually)
under permissions if the camera is listed you scroll back up and disable the app.
i did not disable messenger though
I VE GOT MY CAMERA BACK!
THANK AGAIN!!!!! HOORAY!
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
Guys, this is the solution. It worked in my phone.
go to settings then to applications. See which application is using the camera then force stop or disable it. For my case, I forced stop the application called privacy guard and my camera worked perfectly henceforth.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
how do you determine with app is running your camera
さんによる
さんによる
コメントを追加
I turned off phone took battery out blew off any dust put battery back and cover it started to work again
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
you can't take the back off a htc m8 because you have to take the screen out to get to the back of them
さんによる
Not true mine slips off the back it's a bit hard but does open
さんによる
Not sure about m8 my phone is about 3 years old
さんによる
コメントを追加
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
no this does not work. stop making false solutions
さんによる
This did work for others, that was rude. Not everyones issue has the same cause.
さんによる
コメントを追加
When faced with this problem,
1. Review the last apps you downloaded (Settings>Apps>new downloads)
2. Review to see if it uses the camera for any reason
3. If yes, press the Force stop Bottom
4. If 3 above didn't work, you will have to uninstall the app (s)
I did the above and it turned out an app (Swifty) which I recently downloaded, was the cause of the problem.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
My HTC M8 is brand new from box but camera not working. I have tried to follow all the instructions here but to no avail. What should I do to this brand new hone?
Phillip
さんによる
If u installed Security 360 just remove this app and restart your mobile phone.
さんによる
コメントを追加
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
I found an answer but I can't explain it just yet. I have a program that allows my home screen to rotate. Whenever I enable that program the camera does not work in portrait mode. Just get a black screen. However the camera does work in landscape mode. If I disable that rotate program the camera works in both portrait and landscape mode. Not sure what caused this to happen just yet. I thought I remember it working just fine at first. My guess is something got borked and it will take some cache clearing or something to resolve fully. As for now my work around is just to disable the screen rotation when I want to use the camera.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
What i did is i just stopped the camera ihad!!and i don't know if this is a option for you-but i just downloaded another camera and it's working nicely! Hopefully so can you!!!!----sue
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
I downloaded a new camera but its
still not working
さんによる
コメントを追加
I just opened the back on my phone and fiddled and cleaned it a bit where the connection is, when I rebooted it worked again...
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
I had the same issue even after factory reset. Then I upgraded my software to marshmallow....
The camera is now properly working
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
UPDATE I got my camera back for a while, it broke again. I'm tired of trying to fix this. I have had no camera for a while now
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I don't have no front camera every time I go to the camera and pick the little square box I don't see the selfie sign.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Same issue. Can anyone assist please?
さんによる
コメントを追加
My camera won't work the message" camera has unexpectedly stopped " shows up did all the above and a factory reset and still doesn't work
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I suffering from same issue, if you have any solution please share
さんによる
コメントを追加
I had a lot of problems with my htc...
I'm disappointed....
And also my camera doesn't work
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
My HTC Desire 530 front facing camera has also stopped working...did all the above...no help...very frustrating ..can someone please help all of us ? HTC peeps?
さんによる
سلام مهسا ، مشکلت رو تو تلگرام بگو راهنماییت کنم
@HaCKeR071
さんによる
コメントを追加
Hi
Duo camera is blocked problem after replace camera , plz help me ,
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
HTC makes great phones with too many issues which gives customers tons of migraine. In the long run it's not worth buying.
さんによる
コメントを追加
Has anyone contacted HTC and has their phone fixed? I've had my HTC One M9 for 3 days and this has just happened to me.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My camera it's not working
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
My HTC One M8 main camera has stopped working after change of the accumulator battery. Just a black screen. I will try two solutions provided here - turning off "Autorotate" and switching off all the apps that use camera. Will tell you the result soon...
さんによる
My HTC One m8 selfie camera is not working camera app quits to menu when I go to selfie mode and on other apps like snapchat selfie can shows black image
さんによる
コメントを追加
回答を追加する
Jacob FUEHRER さん、ありがとうございました!
統計データ:
過去 24時間: 8
過去 7 日: 28
過去 30 日: 119
今までの合計 189,369
