メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2397回答 すべてを表示
it wont turn on when off charge
i dropped my iphone 4 once on the floor and it turned off so i went home and plugged it on charge i thought it started working again as it came up with the apple sign but as its about to turn on the screen turns black and it turns off again, it repeats this while its on charge and it wont turn on when off charge can any one help me?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
Check you battery connection. The clip where you battery is connected may have broken free, we've seen this several times. The phone is reaching for the battery for a base charge to start up 1/2 way through the load and isn't getting it. There are several others issues that can cause this type of boot loop, but only a few where the phone is only responsive when plugged in, so this one is most suspect.
"careful with self promotion in "Answers" could be viewed as SPAM"
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
jayde さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 5
今までの合計 31
