メインコンテンツにスキップ
Repair guides for cell phones by manufacturer Nokia, including smartphones and a wide variety of the iconic "brick phones". This category is for phones not using an Android or Windows operating system.
508回答 すべてを表示
Device dead. RTC Battery oxidated
Hi folks,
we are a small telco company from northern Italy. We have a Nokia 6630 with some specialized measurment sw loaded. The sw license is hardcoded to the devide, therefore I absolutley need to fix it ;)
The phone does not start anymore. So I opened it with my protech toolkit and found the RTC battery oxidated. I cleaned the green patina off the battery connector and took out the battery (code XH414H). I desperately need to find a replacement.
Do you know anypne selling these kind of spare parts? did you have any other cases like this?
Thank you!
Christian
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
christiancanal, the XH414H is actually a lead free high voltage-resistant reflowable capacitor rated to 3.3V.
Nominal Voltage (V) 3.3V
Electrostatic Capacity (F) 0.07
Internal Resistance (Ω) 70
Weight 0.07 g
Diameter 4.8mm
Height 1.4 mm
Looks like this one is a match and you can also get them from Digikey.com. Of course that is for the US market, as for Northern Italy, I am not sure. Anytime you have that much corrosion, you will have to clean your board properly with isopropyl alcohol and a soft brush and you will have to repeat that a few times.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
christiancanal さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 244
