メインコンテンツにスキップ
2013年6月に発売されたGalaxy Megaは、720Pディスプレイ、デュアルコアプロセッサ、8 MPカメラを搭載した6.3インチスマートフォンです。
54回答 すべてを表示
締切られた回答
No backlight new screen
Need some assistance. I'm new to Android and I hate them all...lol anyways
Samsung Galaxy Mega SCH-R960, no water damage, probably dropped, I bought it with a cracked screen and defective touchscreen. it was working fine besides that. I shelled out 100 bucks for an entire new housing (screen, back, case ect) and swapped the logic board. Everything went fine, turned on to no backlight. Backlight worked before this. Now I can barely see the LCD even with a flashlight.
I reset everything, took it all apart again redid all connections, tried a lot of things but nothing works. Any ideas what the issue is?
please help thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
please! Any input?
さんによる
コメントを追加
3件の回答
ベストアンサー
Hey Jonny,
So to clarify, you purchased an entire LCD screen and digitizer assembly to replace the cracked screen and defective touchscreen? If this was the case, it sounds like the backlight that came with the new assembly might be defective.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thats what I was thinking, but they said they checked it and the screen worked. I'll plug in the old screen to see whether the backlight works or not on that one and thatll tell me whats up. Thanks!
さんによる
コメントを追加
It was the assembly. The seller noted it as "tested and working" but I guess Mother Theresa makes mistakes too. It happens.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have a Samsung Mega and some how my mother board got wet every thing works on it but my screen doesn't stay on. If you hold a flash light to the screen you can see what's on the screen. The screen will light up and then go black.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,445
