How do I replace the Inverter
how do I replace the inverter?
take the upper cover, unscrew the hinges. be careful to disconnect the wifi antenna cables and the lvds cable. take the screen out of the chassis now. on the screen bezel, under some rubber feet there are screws, this screws, along with plastic clips hold the bezel. take them out. you are in. now is just disconnect some cables and you are good to go
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 255
