メインコンテンツにスキップ
Samsung Galaxy S4はモデル番号i9505、13メガピクセルの背面カメラ、5インチ 1080ピクセルのディスプレイを備えています。
526回答 すべてを表示
Needs battery to be inserted to turn on briefly then shuts down?
Hello, my s4 turns on briefly until the first "samsung galaxy S4" logo just to turn off and refusing to turn on again until I remove and re-insert the battery again. I tried goin into recovery/download mode and even when it allowed me into those modes the phone ended up doing the same thing by turning on for about 4-5 second and then shutting down until I placed the battery back.
Also the phone turn on automatically when i place the battery on it, I dont think that is a normal behaviour is it? I have two galaxy s4 and the one that works doesnt do that. That to say that ive tried two different batteries without success.
I only want to know which part could be giving me the problem so i can replace it with my spare s4.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
I have the same problem! please help
さんによる
i have the same problem :(
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi,
Maybe you have a problem with the Power button (short circuited or permanently pushed). When you press it, do you feel click?
For sure this is a hardware problem and the phone must be opened. You can try to open it careful and check the board for a water liquid. You can found manual here. Disassemble only the back housing / bezel and with magnifying glass check the board (especially near to the battery connector and the power button). If you see a liquid, you can clean it with some alcohol. If this not help you, then search for a help from a specialist.
Regards.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
how do i do that , mines has de the same exact problem .
さんによる
コメントを追加
回答を追加する
Jose さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 3,804
