Replace cracked digitizer front screen
Hi, just tried to replace the front digitizer touchscreen on this device, however despite being able to source a digitizer it appears to be glued to the LCD via a clear double sided sheet and I have managed to destroy the LCD now :(
- so if anyone has any source for this part
On the plus side it is pretty easy to remove the rear cover for access to the battery, just clipped to the bezel so gentle pying of the bezel outwards removes this if you work methodically.
3 件のコメント
We're did you buy the replacement screen
jnmcgahee さんによる
is the tape/glue only around the edges? Or is it entire glued down across the entire face of the lcd?
Graham Pointer さんによる
According to some googling, you have to heat it up a bit because the digitizer is glued to the lcd and any forcing will destroy the lcd. Full lcd replacement costs about $200 and is the easier way to go.
Derik Wilson さんによる
