メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2376回答 すべてを表示
black screen,no backlight, connects to itunes.
After liquid damage.. cleaned logic board, replaced battery/lcd digitilizer.
however screen remains black with no sign of backlight either. I can sort of see slight blackness on the lcd logic board component but wouldn't have thought enough to prevent the screen to not be working plus I would still have the backlight on, and its component is fine. ive checked that its seated in properly into logic board etc.
I can connect to tunes and battery is charging etc, it will vibrate when using the mute button.
would this possibly have anything to do with proximity sensor issue, (on/off button stopped working before the liquid damage) or lcd/digitilizer faulty or logic board?
Thankyou for any feedback
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hello it's possible that the screen is dead and a replacemnt will sort it but with water damage you just don't no
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thankyou for responding. I shall try another new screen and hopefully that solves the issue.
さんによる
If the new screen doesn't work then you no it's the problem with the lcd pins that are a bit black
さんによる
コメントを追加
回答を追加する
Calder さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 5
今までの合計 188
