This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
Brad Klopfer @bradklopfer
評価: 1
投稿日: 2014年8月17日
Must push gas pedal down to start. Will start and run untill I remove my foot from gas pedal.
この質問は役に立ちましたか?
oldturkey03 @oldturkey03
評価: 789.1千
1.1千
897
2.4千
Brad Klopfer, this could be caused by a bad idle air valve. You could try and removed the Idle Control Valve clean the carbon out of it and see if that makes a difference. If not, I would replace it and see what happens. Hope this helps, good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 844
