メインコンテンツにスキップ
Repair and disassembly guides for GE Microwave ovens.
349回答 すべてを表示
The food never even warms.
Hi,
My Spacemaker GE microwave seems to be functioning well, i.e. the lights work, the timer works, and the turntable rotates.
I tried a soft reboot and a hard reboot, after which I was able to reset the clock. The only thing that does not seem to function is: the food never even warms. I am trying to decide if it is time to try to replace the fuse, call an electrician, or replace the appliance, It is 12 years old, and has had no problems until this morning. Thanks for your input!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
If the microwave still light up, then it's not a fuse. the ceramic fuses are on the incoming power supply, so if it blows, you'll have nothing, as in no lights, fan, turntable, etc. There are numerous bi-metal fuses scattered around the unit, designed and located to detect overheat situations, but they should reset after cool down. Possible problem could be the magnetron itself (the thing that generates the microwaves), the super capacitor, or any of a miriad of electronic components on the circuit boards. As oldturkey03 mentioned, the fuse is easily replaced. Worst part is getting to most of them, which requires taking the unit down and removing a dozen or so screws that hold the outer shell on (and then remembering which screws go where upon reassembly). Anything else should be done by a professional. Unfortunately, given what it costs to have a repair done as opposed to simply replacing the unit, the latter is the easier and likely less costly route to take.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Here's a video guide for fixing common faults
https://youtu.be/WAf18e8sW4E
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
jan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 909
