iPhone 5s screen length
Was swapping a white front panel assembly onto a black "slate grey" phone. It seems like the home button end on the white panel is thicker, and this is where it shows that it's also longer. Can anybody confirm this?
The screens should be the same size in all iPhone 5S, if you have one that is a different size then you should return it to the vendor.
このアンサーは役に立ちましたか?
Hi
The screen should fit uniformly onto the iPhone. If it doesn't then you should consult your vendor and either get a replacement or return it for a refund. Find a better quality vendor to buy from next time.
Best of luck
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 131
