メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
Microphone and earpiece not functioning in calls. Intermitten.
iPhone 4 GSM AT&T. I have already replaced the charging port once with an OEM part. It is not a service issue as it works perfect in another iPhone and I have switched SIM's and reprovisioned.
1) The microphone works 100% of the time in Voice Recorder.
2) Every now and then (about 1/3) when a call is made the speaker phone button will be white as if its already turned on.
When this happens, you cannot adjust volume in the call (press volume buttons and nothing appears). I have tried tapping the speakerphone button off and back on. No sound or microphone at all, doesn't matter if speaker on or off.
3) The other 2/3's the call is made fine and the microphone and earpiece work and the speakerphone button is not white as if turned on and the volume adjusts.
I'm thinking possibly noise cancelation microphone (power button flex?) or a software glitch. I have not tried a restore yet, only a update, just looking for some possible input.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
I have a similar problem both ear speaker and mic won't work. I've tried replacing both but still the same. Also mic works in voice recorder
Would like to know a fix
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Is it intermitten on calls, or is it every call you make?
In the next week I will be trying the noise cancelation microphone (replacing the power flex ribbon) and a DFU restore. I will let you know if I have any sucess. Was just hoping for someone on here to be like "Hey, I had that problem... This fixed it :)" lol
さんによる
コメントを追加
回答を追加する
Matt さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 67
