メインコンテンツにスキップ
モデル番号A1225 / Early 2009 / 2.66, 2.93もしくは3.06 GHz Core 2 Duoプロセッサ
164回答 すべてを表示
Computer shuts off after a few minutes of use
Hi,
My iMac (early 2009, 24") started shutting down after a few minutes of use. It's not a clean shut down. It's an instant cut-off of power.
Using Hardware Monitor, everything looks normal except with the Northbridge...
- The voltage sensor always shows 0 volts.
- The current shows 0 as well.
I've tried resetting NVRAM and SMC, but that hasn't helped.
Does anybody have any advise before I replace the system board?
Thanks,
Jay
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
最も参考になった回答
if you haven't already i would try cleaning the dust out, make sure the fan is still spinning, it sounds like a possible overheating issue
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks Michael.
Overheating was the first thing I thought of. I tried all you suggested.
I also tried using smcFanControl to increase the fan speeds. I replaced the thermal compound on the Northbridge as it was running a little hot (about 75 degrees C at idle). It now runs about 5 - 10 degrees cooler. Everything else seems to be running cool.
So far, nothing has helped.
さんによる
コメントを追加
Best to take the frame off and take a look at the diagnostic lights when it goes down. That will tell us where to look.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks Mayer. I did that too. It goes directly from 4 lights to 2. Unfortunately that doesn't help.
さんによる
コメントを追加
回答を追加する
Jay Thomas さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 293
