メインコンテンツにスキップ
統合されたディスプレイを持たない一般的な据え付けのコンピューターです。
How to fix a motherboard that doesn't give display?
I've had around 6 PC motherboards that I have changed over the years. I have all the motherboards with me. The problem with them is that there is a light on the board and the fans turn on when I power up the PC but there is no display. This seems to be a common problem for PC users. I need to know what could be causing such problems and if there is a way to fix it.
Thank You
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 17
1件のコメント
im running a pc with intel pentium dual core processor which is of 2 gb ram
it was the oldest pc of mine switched on after long time
the pc fan got started and hdd is on but im nt reciving the vga signal from the mother board what would be the problem…….
can any one help me to fix out this problem
さんによる
コメントを追加
9件の回答
最も参考になった回答
Denver Braganza, all of this will depend on your trouble shooting skills. It would also help if you tell us what kind of motherboards those are, and if you use the same CPU for all the boards. You said "there is a light on the board and the fans turn on when I power", the light is most likely a 5V power standby light, saying your board receives power. The fan kicking in is also good. Now, I would suggest you try to remove all the RAM and replace it with one known-good module. Then try to restart. You also want to try to use a different video card if you are using to onboard video. Let us know what you find.
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
They are all normal motherboards. But the CPUS are different. ONe is an Intel Pentium 4. One is an old AMD CPU. I don't know about the others I have. I have tried putting a single good RAM and also a working video card but still I don't get any display. The fans keep running. Even the GPU fan. The light stays on. But no display. I have tested the RAM, power supply and graphic card on my friends boards and they worked fined. I think it might be a board problem. Almost every friend I have has the same problem and they have had their boards replaced.
さんによる
I also had a fujitsu laptop but tgey told me i had to change the board because also my display was dead☹️
さんによる
H110 mother board i changed the bois logo its came succesfully after its not coming out put plz tell me solution
さんによる
Denver Braganza - most of the times you can assume CPU is in running order.(except for socket.A). Verry rare cases when CPU fries. (2 instances in 22 years). Most of time a bios reset with no CPU in reinitializes everything. Then reconnecting CPU boots the sys. Ram can go but it usually chip corruption, and it still starts ,with errors.(it's good to have more than 1 module for testing purposes).90% of time is motherboard or psu related problem.
さんによる
コメントを追加
There is a problem of north bridge in the motherboard as it is use to give display to the screens . I was also facing problem like that on my asus mb
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Reheat the north bridge of the motherboard always the problem of asus mb no display.
さんによる
Where is that north bridge located on the motherboard?
さんによる
コメントを追加
clening motherboard ram slats and rams with tinner
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
my name lokman from bangladesh brother if my answere you get helpfull u can pray for me
soloution
1, you see mainboard have two power suply one is 20 or 24 pin secend one is 4 pin at first you open the proccesore cooling fan and than cheq proccesore heating normaly if proccesore not hot plz change electrolitic capacitore you can see this capacitore with 4 pin power suply after that if no display you can change mosfet tranjistore you can see with 4 pin power suply after that cheq your proccesore heat normaly that means your pc is ok
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
What if the cpu processor is heating normally and still there is no display? Ram is ok i checked. Video card is working. Fans are working. PC makes 5 beeps, no display
さんによる
my MSI motherboard doesnt power up when i put atx 4 pinout. but when i unplug atx 4 pinout its running smoothly but no disply. plz help
さんによる
Caps or vrm gone on MSI ,try checking with volt/ohm meter if no visible defects are seen-spoted.
さんによる
コメントを追加
Flash the bios of your motherboard.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Motherboard on and CPU hitting or motherboard properly on and no display monitor what problem please sir
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
First check for bad &bulged caps(capacitors) or leaky ones ,using a ohm meter(if measuring the cap, the needle drops,it's leaking). Second change 3v battery after cmos reset.(sometimes you need to let board sit for a night with shorted out -/+ and no coin battery in.) 3v coin battery life is about 2-3 years in normal use. Some boards don't like 2.9v & under drop.
I salvaged a few boards using above procedures. If still no boot ,check to see if it wants to read floppy or CD after -power-on. It can sometimes be a corrupted bios ,you can fix from disk or cd.
However, listen for bios beeps, it can better determine a issue. If all fails ,maybe a vrm or chip is blown/ short circuited.(more difficult to determine or fix)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Matherbord no display
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Matherbord no disply
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Denver Braganza さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 20
過去 30 日: 80
今までの合計 62,723
