メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iFixitが製造し、iFixit.comで販売されているすべてのドライバー
Are the TR10 and TR8 screwdrivers interchangeable with T10 and T8?
Hi!
Thank you for your great guide! I have a question regarding the Torx screwdriver sizes. I own a toolset that includes T6, T8, and T10 sizes as well as a few others. In your guide, it is listed that a "TR10" and a "TR8" screwdriver is needed. After watching several videos pertaining to hard drive replacement, many people claim that they are using the standard T10 and T8 sizes. Is there any difference between the "TR" labeled screwdrivers and the standard "T" ones? I don't want to have to buy these two screwdrivers if the ones I currently own will work. Please advise. Thank you!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
1 件の回答
ベストアンサー
Here's a breakdown of the more common bits:
画像
The TR (Tamper Resistant) Trox screw has a pin in the middle of the hole so a standard Torx bit can't grab the screw.
このアンサーは役に立ちましたか?
スコア 7
3 件のコメント:
Thanks! Great diagram. I just put in an order for the TR Torx screwdrivers.
さんによる
The TR drivers might be able to work with standard Torx screws, but not visa versa. In about twenty years of working on Macs, I have never actually needed any of my TR drivers. None of the repair-guides I have found acutally calls for a TR driver - perhaps Sebastian has encountered a typo?
さんによる
Johann, Mac Mini 2018 is using TR6 screws.
さんによる
コメントを追加
回答を追加する
Sebastian さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 25
過去 30 日: 107
今までの合計 26,817
