turns on but no display
No display
この質問は役に立ちましたか?
Grdo, connect an external monitor. If that works, your computer may either need a new LCD or inverter. If it does not work, then you are having problems with your GPU and you will have to repair the motherboard.
このアンサーは役に立ちましたか?
where do i get a new LCD monitor and what is an inverter?
このアンサーは役に立ちましたか?
What computer is it, and how do you know it is the LCD that has failed? Did your try the answer above?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 221
