This question doesn't really make sense---it isn't possible to accidentally pull the digitizer flex cable off the touchscreen ic that it is soldered to without significantly tearing the flex. What you are showing is a new digitizer replacement with its flex. Most iPad mini digitizers these days are solder pre-soldered to a touchscreen ic. This one is not. For this one to work, you'd need to solder the flex you are showing to the touchscreen ic chip that you are showing, and then also solder on the smaller flex connector that you are showing.
Align the gold dots with the touchscreen facing up, add flux, and solder away.
If there is any damage to the touchscreen ic, or a bend in the digitizer flex, cold or bridged solder joints, or damage to either flex at the contact pads---then the whole effort will have a poor result.
I would recommend just buying a new digitizer assembly due to the risk that something is already, or will become, damaged in the repair attempt.
6 件のコメント
Please explain a little so I can understand, where you changing the LCD or the digitizer? Has the gold piece come off the logic board?
Please elaborate.
alyn jones さんによる
Wish i could upload a pic!
Justine さんによる
Justine, you can. Follow this "quick and dirty" guide iFixitでの質問に画像を追加する方法
oldturkey03 さんによる
Hopefully the pic will explain what i was meaning!
Justine さんによる
How to get the gold contacts to stay together? Do you use super glue or ????
Justine さんによる
1以上のコメントを表示
