メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
booting from usb external drive
Trying to fix my old PowerBook G4. I found my internal hard drive is dead.
I'm trying to reinstall the Mac OS-X but doesn't find any drives.
I attached an external USB drive (to try to install the software there) but doesn't find it. When I open disk repair, the external drive is there (the internal drive doesn't show)...
Any suggestions? Can I install the operating system in the external USB and boot from there?
Thanks!
David
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
Can you give us the OS-X version you are trying to install.
さんによる
コメントを追加
4件の回答
最も参考になった回答
Sadly you'll need a FireWire HD which has the older OS's this system uses, either OS-9 or OS-X 10.5.8.
Your other option is to boot off of the grey OS installer disks that came with the system or a retail copy of either of the OS's I've listed here.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
If your internal drive is dead it likely needs replacing. Have you done that yet?
Sadly, you can't boot up the older PowerPC based systems (G series) under a USB drive, you need to use a FireWire connected drive and the drive needs to have a bootable OS on it for your system.
Depending on the OS version you are working with here you may need an older version or use a boot disk that was created on a G series system as the earlier versions of OS-X had two installs one for PowerPC based systems and the other for Intel based systems.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Google told me, if any, it can only boot via a firewire harddrive, because it is a notebook before intel or sth like that. Just google it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Just put your new disk into the g4 and make a normal install it from your macosx dvd...
Pd.- if you cant give us more specific details we cant give you more specific solutions
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
david さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 39
今までの合計 1,864
