メインコンテンツにスキップ
Released in 2013 as a budget smartphone in three models/variants, the Idol features a 4.7-inch IPS LCD panel, 1 GHz dual-core processor, and an 8 MP camera. Includes models 6030A or OT-6030A, 6030X or OT-6030X, and 6030Dual-sim or 6030N.
20回答 すべてを表示
cracked touch screen,unresponsive to touch, display without damage
Hi,
my mobile phone fall down and unfortunately my touch screen is cracked. Partially its unresponsive to touch, but LCD is totally OK.
I contacted authorised service centre and they told me, that its only possible to change the whole screen with LCD, not just digitizer (because of adhesive between). Of course, its quite expensive... Thats why I ask for advice. I found on ebay just Digitizer for my phone, but I am not sure, if I will be able to replace it...
Do you have some manual or good advice?
Thanks a lot.
Martina
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 20
22 件のコメント
My iPhone 5 got replaced screen the other day and not its mysteriously cracking and not the is a line crack in the middle of the screen and it is stopping the bottom of the screen working. i replaced it because it was badly cracked but not problems still worked but now a tiny crack is stopping it from working I really don't get it and i cant afford another £50 to get it replaced again.
さんによる
This is what happened to my iphone 5! It was badly cracked, I got it replaced nearly last week, it was working ok, but honestly really slow, and freezing constantly, but it was still working. Today, I noticed a long crack line down the screen, that I have never noticed before... all of a sudden, it wont respond at all, literally at all! I can't pay $150 again.. this is the 3rd time I've gotten it fixed by the same guy, and they charged me $150 each time.. now it's not working?! over 1 crack! I don't know what to do.
さんによる
Hi. I dropped my iPhone 5c last night. When I dropped it, the screen was totally cracked. And the screen was also glitching. After a while. A red light appeared by the earpiece when it wasn't even near water. And now the screen won't turn on. Only a black light. What is wrong and what can I do to fix it
さんによる
Well my advice it and do not do it yourself. Go to your service center and get it replaced. In future use a good quality tempered glass screen protector having 9H hardness rating for protection. You may consult this http://www.akshatblog.com/use-glass-scre...
さんによる
Our Lenovo S8-50LC tablet had been dropped on the concrete-floor and its touchscreen was cracked. Although the LCD is unbroken, the display seems non-responsive to touch. Several commerce site is selling just the touchscreen for my tablet model. Can anybody tell if just the touchscreen is repairable without changing the LCD for the particular tablet model (Lenovo S8-50LC)?
さんによる
17件以上のコメントを表示
コメントを追加
8件の回答
ベストアンサー
cambiar el lcd(change the LCD)
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Martina,
It sounds like you probably won't be able to replace just the digitizer. Many new smartphones feature screens where the LCD panel is fused to the digitizer (Like yours). This makes the phone thinner, but harder and more expensive to repair. If you want to fix your screen, you're unfortunately going to have to replace the whole display assembly (LCD&digitizer).
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Ciao! Or, as me, you have to buy a molibdenum wire to separate it heating with a heat gun and a tube of loca glue. It's hard to do.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
للأسف تحتاج الى تغير الشاشة بأكملها
Google Translation
"Unfortunately you need to change the entire screen"
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
@lpfaff1 @pccheese Gentlemen this is a valid answer. Please reverse your request in moderation.
さんによる
Thanks OT, redid translation differently today and your correct!
さんによる
My moto 1 cellphone broke totally so can I get back my all the data like pictures ,music n app... Apart from all,, from backup I got my pitures some of.. So can i get all
さんによる
コメントを追加
It is possible but very hard to replace both in the first place. But it is almost impossible if your not super good to replace just one. I did two screen and LCD repairs and lost screws and stuff single inside.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The problem is that the screen has cracks, yet you cannot see them due to the depth of the crack. Therefore if the crack(s) disturb the digitizer and its components the system will not be able to recognize any contact with you or a stylus. You would have to replace the LCD Touch Screen and Digitizer. This is not to hard to do and you'll save more money as you can purchase the new touch screen and digitizer on ebay and required tools on iFixit...
Hope this helps
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Does not let me tap or touch the middle screen an i really need help
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Martina さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 31
今までの合計 239,911
