メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
Frozen, black but still making noise. Reset or restore will not work!
Okay, so I know you're going to suggest the lock/home button, but the problem is my lock button doesn't work.
I bet you're going to say "Well, Meranda just connect it to your computer and restore it." Well bad news, my name doesn't pop up in itunes when I do connect it to my laptop.
This happened yesterday, an app froze so I put it in sleep mode but now it won't turn back on. I thought it was completely broken until I heard a noise indicating that I had an email. I read some things where it suggested I wait until the battery dies, and then try but the thing is I have waited. Surely it wouldn't take that long for it to die, would it?
So with the inability not to do the lock/home button or restore it, do you guys have any other suggestions? Please help me, I will love you forever.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
My advice would be to plug in a new lock button, you don't even have to install it fully. Simply plug it in a try that reset. As an expericanced tech I can tell you that this is a fix for A LOT of things when they start acting buggy. I would also try connecting a screen and see if it is your LCD that has gone out. If you don't want to order a new lock button and try that I would try a battery reset by disconnecting the battery and reconnecting it however you should make sure that you are grounded (ESD safe)
Hope this helps!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
merandamarie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 252
