メインコンテンツにスキップ
Macハードウェアー言い換えるとAppleによって製造され外付けドライブや電源アダプター、ケーブル、コンバーターを含む Appleの製品にプラグインされるものです。
1112回答 すべてを表示
How to open up PowerBook G4 adapter
I have use PowerBook G4 but my pad bite the cable from the adapter. could anyone tell me how to open up the adapter.?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Why not just splice the cable? Why would you need to open it?
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Done it and it works +
さんによる
Works for me + Ralph
さんによる
コメントを追加
It's machine pressed together when manufactured. This is so the is no chance a consumer can "accidentally" open and become harmed from the high voltage inside. I would just buy a new adapter. Even if you manage to open the adapter you raise the risk of a potential fire 10 fold. I really wouldn't attempt this unless you are VERY familiar with high voltage circuitry. I don't mean to discourage, but just make sure you understand the risks involved.
Best of luck!
-Varsity
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I've actually opened one of these adapters before- it's pretty difficult. You'll need a hammer and screwdriver/chisel to get the thing started. Just tap around the edges, and eventually the thing will crack. Be advised that you can in fact zap yourself (I did it multiple times), but there isn't really enough juice in there to hurt you, unless you leave the adapter plugged into a source of power.
It's really pretty difficult to fix any of the internals- everything is so tightly wedged together that you'll have a hard time getting things replaced. At any rate, if you're going to do any work on it, you should make sure you're good with electronic circuitry.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
elswinlpr さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 9
今までの合計 1,399
