メインコンテンツにスキップ
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
60回答 すべてを表示
How do I get the internal sd card out?
I have a droid razr that no longer goes past the "red eye" startup screen. I got a new phone, but would like to get my contacts and pictures off the old phone (I didn't realize they weren't on the external SD card). How do I remove the internal memory so I can do this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
Peter you describe things as external and internal SD card. Just to clarify, you removed your SD card and the files you were looking for (contacts etc. are not on there). There really is no internal SD card. The RAZR uses a 16GB EMMC Flash Memory IC. You can not access that memory by simple means. You can either try and fix your RAZR so you can access the files needed or have a professional data recovery service do it for you. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Peter さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 622
