メインコンテンツにスキップ
2.3L 4cyl or 3.0L V6, 6th Generation
427回答 すべてを表示
My tachometer isn't reading correctly on my 1999 Honda Accord V6.
When I take off fast it goes all the way past 8500 RPM'S . if the motor was really turning like that it would throw a piston through the hood. Can somebody please tell me what to do....
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
2 件のコメント:
What is your RPM's when idle? and does the engine keep reving when idle?
さんによる
It idles at between 1000 and 1100 RPMS. No it don't surge. I think its just not calibrated right. It had a 2.3 and was upgraded to the 3.0..
さんによる
コメントを追加
1 件の回答
From what I'm reading, the most common fault that causes this is a faulty ignition coil, like the internal resistor is shot. Though it could also be a fault in the electrical wiring its self, a sensor problem or the tachometer cluster. Have you checked those out? Also, you wouldn't happen to have a Vehicle Diagnostic Code Reader? You might be able to find the fault code of whats causing this.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Ran em and it says O2 sensor
さんによる
Thanks for the information.
さんによる
コメントを追加
回答を追加する
Joey Evans さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 528
