メインコンテンツにスキップ
モデル番号はA1236で4もしくは8GB容量
Why is it malfunctioning after replacing the battery?
I have replaced the battery as directed. The display lit up, with a blank screen upon powering up...but that's all. After approximately 2 minutes it beeped twice, and there were dark bands on the lower area of the LCD display. Now it just beeps every 2 minutes.
After being plugged into a charging dock for 30+ minutes the lower half of the display has alternating bands of black and dark grey, and is still beeping twice every 2 minutes.
I used a soldering iron that was not calibrated...might I have fried the pcb?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
The problem you describe is due to damage to the screen.
The beep you describe maybe that replacement battery that is not good ..
If I were you I would try to change the screen display, do not think that damage to the PCB because it lights up.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
maryellenhart さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 438
