メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
締切られた回答
Awful iPhone situation. NEED HELP!
So I probably have one of the worst iPhone situations ever right now. I was tried to erase and factory reset my iphone this morning, using(settings>general>reset) option, and for some reason it froze during the boot and has been stuck with a circling logo.
I plugged it into my computer and was just going to restore it with latest ios7.1.2 but itunes won't recognize my iPhone. It doesn't show up when I plug it in.
I did some digging online and found out that you can get itunes to recognize your device if you put it into DFU mode.
Thing is, my power button is broken. So I can't put it into DFU mode!
There are few programs over internet that will allow me to put my phone into DFU mode without having a power button, but they all require my computer to recognize my phone when I plug it in. Can someone please tell me what to do I've spent hours trying to get this to work and so far nothing has. I have struggled a lot to buy this expensive phone & this circling logo hurts a lot.
I am looking forward to hear from you if there is any way..
(Here is no iphone customer care in Bangladesh)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Hey man! I have the same exact problem right now! Have you found a solution?
さんによる
コメントを追加
3件の回答
最も参考になった回答
I would start with replacing the broken power button. You will find it on this site. I do not think it cost more then about 20 USD.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Try holding down the Home button and plug it into your computer. This will put it into recovery mode - I am not sure this will cause the computer to recognise the phone, but it is worth a shot.
I will do some digging and see what I can find, but as of now, I don't know any way of putting the phone into DFU mode without the power button or by using a 3rd party program
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I had same problem iTune won't recognize iPhone or power on, how I got it to work was pulled screen removed screws from battery plate, connected usb to computer got beep but still won't recognize iPhone 5 removed battery connector causing iPhone wake up and iTune then power phone on and said needed to restore. Removed iPhone from power reset battery reconnected iPhone recognized restored working all ok at this time hope it helps.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 124
