メインコンテンツにスキップ
Swap motherboard with A1226?
I bought a used Macbook Pro A1211 not realizing that not all Core 2 Duos can boot into 64 bit mode. I know that the next models, the A1226 can, and are nearly identical to the A1211. So I was thinking about getting a motherboard for an A1226 and swapping them, but I worry about problems with the few differences such as the display. Does anyone know if this would work?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Alternatively, I have been doing some more research and am now thinking a processor swap would be better if it will work. I have seen mentions of this being done in PCs, but they almost always need a BIOS update or something to make it work. Can this be done fairly easily in MacBooks? If so, how much newer can I go?
さんによる
コメントを追加
1 件の回答
ベストアンサー
CPU's on 99% of all laptops, and 100% of Mac Laptops are soldered to the logic board. Not a DIY repair/replace.
A quick check of the parts catalog would show you that you can often swap logic boards within models (but not across years), and almost never across models. Holes, insulators and cables will not line up.
If this answer is acceptable please remember to return and mark it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Tim さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 208
