メインコンテンツにスキップ
An HP desktop computer released in 2008.
12回答 すべてを表示
締切られた回答
No vgi input...monitor goes to sleep
Upon starting up my hp desktop I see the source input menu on the monitor and it states there are no vgi or dvi inputs and then the monitor goes to sleep and I have no screen to work with in order to troubleshoot this issue. Also, according to someone on YouTube, this is a dirty ram issue. So I have tried that fix with no positive outcome. I have also plugged my monitor into a laptop and it works, so it is not the monitor or the cord. What now?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Brent, sounds like your video card is not sending any signal to your monitor. If you use the integrated video card, try a separate video card. There are some issues with the GPU an this model and a reflow of the GPU could resolve it, but try to see what you get when you change the video card. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
could you explain what a GPU reflow is? i'd like to know what i'm getting into if this video card fix doesn't work.
さんによる
https://www.youtube.com/watch?v=VldNJ7Iv... different model same principle
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 7
今までの合計 783
