メインコンテンツにスキップ
Model A1138 / 1440x960 screen resolution
85回答 すべてを表示
Can broken adapter stem be pushed out after G4 disassembly?
I see your excellent step-by-step tear-down of the G4 ("Installing PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card") but is it necessary to replace the DC-In board at the end or can a broken stem just be shoved out?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
2 件のコメント
Thank you both for your thoughtful replies. Will try. FF
さんによる
In the end, after much consternation and a little money invested in the tools, I pried the thing out with a paper clip. Big relief. Thank you for your kind and excellent help. FF
さんによる
コメントを追加
2件の回答
最も参考になった回答
Sometimes the small metal bar on the back of the DC IN port can be gently pulled out enough to release the broken tip. Once the tip is out, just push the bar back into place.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
+ Ralph
さんによる
コメントを追加
I recently repaired my PowerBook G4 15" Aluminum 1.0GHz DC/Usb Soundcard for the exact same reason. It is NOT possible to push the stem out from behind the jack because it is enclosed. I removed the stem by lying on the ground, computer partly supported by my coffee table with the dc part off the edge, and used a safety pin to depress the latch that is inside the jack, then wiggled the computer around until the stem came into center view. I used very sharp tipped tweezers to grasp the stem and then pulled it out. The tweezers are NOT house-hold type tweezers but the type used to work on electronics. Hopefully your board is not damaged. Hope this helps.
Update
Did you try a replacement charger to see if it works? Sadly, I had to replace my USB/DC Soundboard in the the end
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Frank Farley さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 1,204
