How to get push down battery so iPod screen will fit?
Hi, I was finishing up on replacing the screen on an iPod Touch 4th Gen and as I went to lay it down it did not go down flush. Something was pushing behind the screen. I checked for glass or other loose parts. I noticed that metal plate in between the screen and the battery curves out a bit. The only thing that seems to be causing it is the battery.
I haven't taken the battery out at all. The top of the battery seems to have a wire that's built in that starts out on the top outer edge on the right but as you follow it left travels over the edge and onto the side that that touches the metal plate. Is there anyway to move that cable in the battery or would I have to replace the whole battery. I don't know how the first screen fit in if that that cable was pressing against it the whole time.
Any advice is greatly appreciated.
Thanks in advance!
この質問は役に立ちましたか?
