メインコンテンツにスキップ
LED、白熱灯、およびその他の携帯型懐中電灯の修理。
28回答 すべてを表示
Where are the hi/low settings on a Rayz LED Flashlight?
I have a Rayz flashlight.It says it has a high and low setting. how do i use the settings? idem number 180900
1000 lumens
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
We have the same question....no directions with this flashlight and we are unable to get the low setting?? TY
さんによる
コメントを追加
7件の回答
最も参考になった回答
I finally figured it out (with help) after many clicks and playing around with it. I was starting to assume that it was typo or something on the packaging but the two settings actually exist.
You 1) turn it on 2) gently hold in the power (without it clicking). You hold it in about half-way. It's tricky because both settings are close and hard to tell the difference, but the lo-power is there.
このアンサーは役に立ちましたか?
スコア 5
4 件のコメント:
Way to go on answering a very tough one!
さんによる
Sorry, I don't see any difference when following this procedure.
さんによる
Thanks for spending time figuring it out
mdr903
さんによる
Kinda repeating what Jason said but I thought I'd give my two cents. My father bought a few of these flashlights and found them at True Value for right at $20 each. Seem to be done decent lights and blows my super expensive StreamLight away. There actually are hi and lo settings but it's barely noticeable. While the light is powered on just gently tap the power button barely depressing it without turning the light off and you're in low setting. Again, the difference is just barely noticeable...
さんによる
コメントを追加
Alright, here's another question on the same item. I own a RAYZ flashite and it's recent decide to BLINK when on and I can't get it to burn steadily? Any idea. I can't seen to find a company website or a distributor on the web.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I found the distributor (Promier - 815-223-3393) and they are sending me a replacement. There is no fix!
さんによる
Thanks for the phone #, my unit stopped working and they are sending a new one. Great customer service.
さんによる
コメントを追加
Actually first click is bright on 2nd click is off 3rd click is dim on and it keeps alternating. Try it you will see a slight difference in brightness. Hence the 3 terminals on battery pack.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You switch between the high & low settings using the tail switch. One click turns it on to the high setting and rapidly clicking a second time gives you the low setting. However there is not much difference in the intensity between the two settings.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Thanks for all the help here, I had the same question. Has anyone found that turning it focuses it all?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Does anybody know how many watt the led is?????
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
turn the flashlight on and then press the button again for low beam.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mike さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 13
今までの合計 4,191
