メインコンテンツにスキップ
The TH (turbo-hydramatic) 700R4 was developed for use after 1982 in GMC and Chevrolet cars and trucks.
35回答 すべてを表示
Help with setting the 700r4 tv cable.
I have a 1972 Corvette that I put a 700r4 transmission in and have a question. I have been trying to adjust the tv cable as everyone has told me to Push down on the release tab and push the center tab in on the end of the cable, then go to full throttle and it should then set the cable to the correct setting meaning the center tab should click into place. Mine is free and moves easy, its a new cable and its being put on an Edelbrock duel guad carb setup. However it doesn't click out at all, no movement. Does that mean that it's set and doesn't need anything further? Or does it mean that the throttle lever and tv cable end aren't traveling far enough? I have went so far as to pulling on the cable end to see if it will click out and it does.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Fixed it today by taking the transmission pan off and setting it visually in the transmission.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
what does that look like?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mike Jones さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 1,741
