メインコンテンツにスキップ
Wi-Fi, GSMとCDMA モデルのiPad第二世代です。あるモデルはiPad3発売前に改良されたものがあります。修理は困難で、熱で温めてこじ開ける作業が必須です。
730回答 すべてを表示
締切られた回答
iPad 2 reboots after drop. Quick help needed.
Hello,
A customer brought in an iPad 2. After a drop the iPad doenst start anymore. It shows the apple logo and then it shows stripes all over the screen and shuts down. It does this repeatedly. See video:
http://videobam.com/zRdjs
Anyone has a solution for this? I disconnected the battery, but then the iPad doens't start at all.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Anyone with a solution?
さんによる
コメントを追加
2件の回答
Take at the dock connector any damage? also try connecting the iPad to iTunes and doing a restore.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
This is called a boot loop. Apple says to do this:
Use recovery mode
Recovery mode erases your device and restores it, which should resolve the issue. If you previously synced with iTunes or iCloud, you may be able to restore from your backup after recovery.
Turn off your device. If you can't turn it off, press and hold the Sleep/Wake and Home buttons at the same time and wait a few seconds for it to turn off.
Plug the device's USB cable into your computer only.
Hold down the device's Home button as you connect the USB cable to it.
When you see the Connect to iTunes screen, release the Home button. If you don't see this screen, try steps 1 through 3 one more time.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
thanks for the reply's. However none of this works, because the iPad doesn't boot i cannot be seen in iTunes. Also recovery / DFU mode does not work. Using another dockconnector doesn't make a difference.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 170
