Permanently deleting files on my Windows PC?
I have a few private pictures I'd like to ensure are permanently gone. From what I know the gutman method is supposed to be efficient - any ideas?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
There are many programs implemented with the Gutmann method you've mentioned, especially by overwriting file patterns. If you only want to erase multiple files and not wipe the entire drive, use Eraser. Not sure if you already know this program, but it's essentially a file shredder. It is a freeware and open source security tool to completely remove certain data from HDD. It can overwrite data several times using randomised patterns of binary code.
Or, you can use Recuva to find any files that have already been supposedly deleted but still are recoverable, and then securely overwrite them. Be sure to set Recuva to a high number of passes for secure overwriting as well. It'll overwrite the portion of the hard drive where the file lives repeatedly until it "decreases" its chance of recoverability
Hope that gives you a bit of ideas
このアンサーは役に立ちましたか?
Hey Roochie, thanks a lot for the advice. Both of the programs are exactly what I was looking for! Thanks mate. :)
過去 24時間: 2
過去 7 日: 4
過去 30 日: 4
今までの合計 141
