メインコンテンツにスキップ
Dell 19" LCD Monitor, charcoal gray in color, released in 2004.
8回答 すべてを表示
Display darked out in 1 second
My Dell has very similar board layout as this one. It display for about 1 second after each power on and then darked out. Power off and on again give me another second but that's is. I shine a strong light on the screen in the hope that I can see a shadow of the display but nothing. With help from this site, I tear down the case but not able to troubleshoot because of my limited knowledge.
With the power supply board alone (not connect to any other board), tested it and all +5V and +12V output are ok and very stable. Found a pin labled "on/off along the DC out to the controller board (i.e. the one with the VGA port). But no matter I connect ground or +5V to it, the inverter still has nothing out.
Can anybody give me an idea how I can troubleshoot the problem? Thanks in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
senderj, sounds like a bad inverter. You can try to recap the PSU or replace it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
senderj さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 7
今までの合計 518
