メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
締切られた回答
Stuck on apple logo after screen replacement
Replaced my iPhone 5's screen which is something I have done many times before a fairly easy procedure. But this time after installing its stuck on the apple logo and wont boot up past that. I have opened the phone back up to check everything was connected properly and I'm fairly sure it is. My next move was to restore the IPhone in recovering mood so I tried that and its come up with a mix of error (9) and error (21). I have tried updating iTunes, tried a different computer, different cable, different usb port but can't seem to get anything to work. I didnt have any issues with this phone prior to replacing the screen. Thanks in advance to anyone that can help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Have you tried a soft reset? Press and hold the power and home buttons until the screen goes blank , then release when you see the Apple logo appear on the screen.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
yes have tried this and it was unsuccesful, thanks anyway.
さんによる
コメントを追加
Hello there did you remove the battery as error 21 is a battery issue?
You may have damaged it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,136
