メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2013年9月10日に発表されたApple iPhone 5cの修理情報および修理ガイドです。モデル:A1532、A1456
How can I fix a keyboard problem?
iPhone 5C keyboard will not type certain letters after screen repair. Everything else works fine except for the keyboard. It wont allow me to use the numbers button. Tried a hard reset. Did not work. What can i do?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 13
コメントを追加
6件の回答
ベストアンサー
If a different "known good screen" does the same (a whole batch can be bad), then the issue can be with a chip on the board that controls touch. It would be partially separated from the board, causing some areas of the screen to become unresponsive.
But really must try a new known good screen first, as this is still the first suspect.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
最も参考になった回答
Sounds like a faulty digitizer to me, or a poorly seated digitizer connector. Did you do the screen repair yourself, or did you have a repair shop do it?
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
My sreen is smashed but this was happening before i
Smashed it
さんによる
no it was not
さんによる
I had the repair shop to do it.
さんによる
You should tell your shop about it. If a different "known good screen" does the same (a whole batch can be bad), then the issue can be with a chip on the board that controls touch. It would be partially separated from the board, causing some areas of the screen to become unresponsive. But really must try a new known good screen first.
さんによる
コメントを追加
Usually, the problem occurs after a screen has been replaced and the digitizer cable has not been seated properly. You have to ensure the correct sized screws fitted into the correct position. There are four screws holding down the shield that covers the display cables and if you mix them up then your shield and cover will not fit correctly and the cable connectors will move and cause digitizer and screen faults. Uisung #000 screwdriver you can easily remove and refit these screws, if you are unsure the bottom two are the smallest (1.3 mm screws) and then the upper left is slightly larger (1.7 mm screw) and the far right screw is the largest of them all (3.25 mm screw). You can prior to the removal use a coloured marker or pen and colour code the screws to the position they belong to, remember the two lowest screws (1.3 mm screws) are the same size so can be coloured the same. This should help resolve any problems with exchanged screens and cabling to screen faults. Thanks guys
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
hello,
this is in relation with touchscreen ic chip when everything is all right...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
My keyboard is frozen also screen
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
my iPhone 5s I got the screen repaired and the u and n dose not work on the keybord
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
keldavis5 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 25
今までの合計 31,831
