check engine code P0113.
I have a book that tells me what this is, but not sure where it is on the car! I tells me that it's a - ( IAT sensor 1 circuit hi input ) where is it in the car??
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Bryan , P0113: INTAKE AIR TEMPERATURE SENSOR CIRCUIT - HIGH VOLTAGE
Description
The Intake Air Temperature (IAT) sensor is a variable resistor. The IAT sensor has a signal circuit and a low reference circuit. The IAT sensor measures the temperature of the air entering the engine. It is located in the air snorkel in between the air box and the throttle body.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 20
今までの合計 2,563
