メインコンテンツにスキップ
Sony Ericsson Xperia Arc Sは、Android 2.3.4対応のスマートフォンで、1.4 GHz Snapdragon CPUと14.4Mbit / s HSDPAを搭載しています。
Cannot turn on device, charging or not
When I press the power button, the unit sometimes can be turned on, sometimes not.
Recently, it is totally dead. Even I have a fully charged battery or connecting to a USB cable, the unit has no response to the power button.
No red light when I charge the unit as well, i.e. the unit won't charge.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
1 件の回答
最も参考になった回答
Hi,
If the battery voltage is OK then clean the battery connectors. Check what happens when you connect it to the PC. Connect the device until you hold the Back key (down left key). If the windows see the device in the "Device manager" then may be you have a software problem.
Try a Hard reset. Press and hold left and right buttons under the screen. Press and release the Power button. Follow the instruction for a hard / factory reset.
!!! This will erase all your data !!!
Next, you can try SW update with the PC Companion or directly with the Sony Update Service.
If you haven't reaction from the windows for connected device then yo have a hardware problem.
Regards.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Thank you very much for your advice. It is very appreciated.
device manager cannot see the device. guess it is hardware problem. anything i can do?
さんによる
No, you need a mobile phone specialist :(
さんによる
コメントを追加
回答を追加する
Peter さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 7,869
