メインコンテンツにスキップ
CDMA iPad 2モデルの第二世代は16、32、64GBのオプションがあり、Dual Core A5プロセッサが搭載されています。モデル番号はA1397です。修理は細かい作業が含まれ、熱で温めてこじ開ける作業が必須です。
52回答 すべてを表示
Cracked screen fixed but now colors are wacked. Logic board bad?
I had a cracked screen in my iPad2 3g. Worked OK except for the screen. Felt like the repair would be too much for me so I took it to a repair shop that advertised fixes. They replaced the screen in about 90 minutes but now the display is all red. They said they tried a couple of different screens but they all ended up with the color issue, and diagnosed the problem as a logic board issue. Sound right?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
yes, but totally repairable.
i fixed one like this before and it turned out to be one of the tiny little components right near where the LCD flex plugs into the board. just replaced that one little filter and display was normal again.
This is the shop's fault--it is pry damage.
feel free to contact me via my profile if you need help finding a place that does board level repairs like this
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Any chance re-seating or replacing the LCD display cable might help?
さんによる
sure--but while you're at it, look really closely under magnification for board damage. btw--since the shop removed the original adhesive, i bet your screen will come off really easily now with just a little bit of heat. watch a video to know where the wifi and power flex cables are, and then give it a look. if the devices is powered off it is safe to try and reseat the connector and have a look around
さんによる
Thanks, Jessa, Josh and Rany! This is super helpful. I'll be in touch Jessa.
さんによる
コメントを追加
totally agree with Jess
If you use metal pry tools instead of plastic, you can cause issues like the one you are having. Its an expensive lesson to learn but that shop needs to learn it. Chances are they grabbed the LCD cable with a pair of pliers and blew a filter.
Plastic tools people!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
David さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 6
今までの合計 399
