メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
締切られた回答
black display after reparation of the power button
Hi, I had a problem with the powerbutton on my iPhone 4S. I bought a new flex calble for the power button and followed your instructions. Everything was ok but when I wanted to start the iPhone I only got a black display. The button works - I feel the "klick" - and there is power on the battery. You can feel the engine start but I have a black display.
Are there any typical mistakes which can occour by following the guide and are there any solutions?
With kind regards
Martin
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Just make sure the connectors are seeded correctly.
As so plug into computer and make sure ITunes reconises it .
If it reconises it and still black screen and connectors ok then it's a damaged display
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
well my display was absolutely fine before I did the repair. My itunes recognieses the iphone without any problems. The connectors are on the right position. is it possible that they are polluted? And how could I solve it? Tanks in advance!
さんによる
コメントを追加
Try Reset, hold both home and power buttons for about 10 seconds until the iPhone begins to restart itself.
As con said, make sure the LCD Display flex is perfectly connected to logic board.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
well the screen becomes lighter at the edges when I press the home button but there is no nromal screen. Is it possible that the connectors are polluted?
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 68
